Wisefab Ultimate S-Chassis steering angle kit.
Thread in 'Driftworks Products & Enquiries' started by PhilMorrison, Feb 6, 2018.
  1. PhilMorrison
    PhilMorrison WholeLifeCrisis
    Staff Member
    Birmingham.
    Driftworks are one of the biggest global dealers of Wisefab - & we have a large first batch of the new Wisefab Ultimate S-Chassis Lock kits due in stock now. - Shop here
    Forgive the picture quality, we'll get some pro shots done next week.
    S14Version2Kit.
    After eight years of success in pretty much every drifting championship in the world with the original Wisefab S13, S14, S15 kit, Wisefab went back to the drawing board to create the Ultimate S-Chassis steering angle kit with the help of Formula Drift 2017 Champion, and our good friend James Deane.
    JamesDeaneUnderneath.
    It offers improvements in: Useable steering lock, strength, steering feel, steering ratio, weight, suspension range, adjustability, and a new option for a steering rack relocation fabrication kit.
    The two options for this new kit. Both of them fit S13, S14, S15 Right-hand drive & Left-hand drive cars:
    Option One: Lock kit complete with steering rack relocation hardware. This requires the OEM front subframe to be cut and welded. It moves the rack an incredible 46mm forward for better Ackemann curve to dramatically reduce over centering (when the steering gets jammed on full lock while decelerating / braking). It also lowers the rack slightly for improved engine oilpan clearance. It conforms to all big drift championship rules, and has gone through a full Formula Drift test and approval process.
    S14Version2Kit2.
    Option Two: Lock kit with 30mm rack offset spacers instead of the rack relocation. This is a much more bolt on solution for those not keen on cutting and welding the front subframe.
    Here's the version with the offset rack spacers:
    S14Version2KitOffsetRackSpacer.
    Both version are available to purchase in the shop. Finance is available to UK customers, and all of our international shipping rates in the shop are accurate -
    Check it out here: https://www.driftworks.com/nissan-s...-steering-lock-kit-angle-kit-s13-s14-s15.html
    And if you have any questions about this kit, or any of the other Wisefab kits we stock and supply, please let us know.
  2. Shire Motorsport
    Cirencester
    Do they come with full instructions for wen cutting the front subframe
  3. PhilMorrison
    Staff Member
    Birmingham.
    Yes, we supply each kit with a comprehensive instruction manual for the subframe modification. It's a very very good bit of kit! I was really impressed with the level of detail the Wisefab guys went into on this one.
  4. Shire Motorsport
    Cirencester
    Mint I’ll get and order one then do you deals if front and rear is ordered
  5. PhilMorrison
    Staff Member
    Birmingham.
    Hi, sorry only just seen this. Yes we can do 5% off if you buy a front and rear kit together. Drop us an e-mail and we can set you up with the discount code.
