KW Variant 1
1382 Products
Set Descending Direction
  1. KW Variant 1 Coilovers For Audi A3 (8V) 2WD with 55mm susp strut without electronic dampers convertible - 1028000U
    1028000U
    • Model Year - 03/14-
    • Engine Power(KW) - 81-140
    • Max Weight - F: 981-1090 R: -1050
    • Lowering Front(mm) - 30-60
    • Lowering Rear(mm) - 30-55
    £1,174.00 £978.33
    £1,174.00 £978.33
  2. KW Variant 1 Coilovers For Audi A3 (8V) 4WD with 50mm susp strut without electronic dampers convertible - 10282017
    10282017
    • Engine Power(KW) - 110-140
    • Max Weight - F: -1140 R: -1130
    • Lowering Front(mm) - 30-55
    • Lowering Rear(mm) - 40-65
    £1,174.00 £978.33
    £1,174.00 £978.33
  3. KW Variant 1 Coilovers For Audi A3 (8V) 4WD with 55mm susp strut without electronic dampers convertible - 10282016
    10282016
    £1,174.00 £978.33
    £1,174.00 £978.33
  4. KW Variant 1 Coilovers For Audi A3 (8V) 2WD with 50mm susp strut with electronic dampers incl. saloon + Sportback with twist beam rear axle - 1021000X
    1021000X
    • Model Year - 05/12-
    • Engine Power(KW) - 77-140
    • Max Weight - F: -980 R: -1050
    £1,371.00 £1,142.50
    £1,371.00 £1,142.50
  5. KW Variant 1 Coilovers For Audi A3 (8V) 2WD with 50mm susp strut with electronic dampers incl. saloon + Sportback with twist beam rear axle - 1021000Y
    1021000Y
    • Max Weight - F: 981-1080 R: -1050
    £1,371.00 £1,142.50
    £1,371.00 £1,142.50
  6. KW Variant 1 Coilovers For Audi A3 (8V) 2WD with 55mm susp strut with electronic dampers incl. saloon + Sportback with twist beam rear axle - 102100BG
    102100BG
    • Max Weight - F: -1080 R: -1050
    £1,371.00 £1,142.50
    £1,371.00 £1,142.50
  7. KW Variant 1 Coilovers For Audi A3 (8V) 2WD with 55mm susp strut with electronic dampers incl. saloon + Sportback with IRS - 1021000U
    1021000U
    • Max Weight - F: -980 R: -990
    £1,371.00 £1,142.50
    £1,371.00 £1,142.50
  8. KW Variant 1 Coilovers For Audi A3 (8V) 2WD with 55mm susp strut with electronic dampers incl. saloon + Sportback with IRS - 1021000V
    1021000V
    • Max Weight - F: 981-1080 R: -990
    £1,371.00 £1,142.50
    £1,371.00 £1,142.50
  9. KW Variant 1 Coilovers For Audi A3 (8V) 4WD with 55mm susp strut with electronic dampers incl. saloon + Sportback with IRS - 1021000T
    1021000T
    • Max Weight - F: -1100 R: -1080
    £1,371.00 £1,142.50
    £1,371.00 £1,142.50
  10. KW Variant 1 Coilovers For Audi A3 (8V) with 50mm susp strut with electronic dampers with IRS - 102100AB
    102100AB
    £1,371.00 £1,142.50
    £1,371.00 £1,142.50
  11. KW Variant 1 Coilovers For Audi A3 (8V) with 50mm susp strut with electronic dampers with IRS - 102100AC
    102100AC
    £1,371.00 £1,142.50
    £1,371.00 £1,142.50
  12. KW Variant 1 Coilovers For Audi A3 (8V) 2WD with 55mm susp strut with electronic dampers for convertible with IRS - 1021000Z
    1021000Z
    £1,371.00 £1,142.50
    £1,371.00 £1,142.50
  13. KW Variant 1 Coilovers For Audi A3 (8V) 2WD with 55mm susp strut with electronic dampers for convertible with IRS - 102100AA
    102100AA
    £1,371.00 £1,142.50
    £1,371.00 £1,142.50
  14. KW Variant 1 Coilovers For Audi A3 (8V) 4WD with 55mm susp strut with electronic dampers for convertible with IRS - 102100AH
    102100AH
    £1,371.00 £1,142.50
    £1,371.00 £1,142.50
  15. KW Variant 1 Coilovers For Audi S3 (8V) without electronic dampers incl. saloon + Sportback - 1021000M
    1021000M
    • Model Year - 05/13-
    • Engine Power(KW) - 221-228
    • Lowering Front(mm) - 0-30
    • Lowering Rear(mm) - 5-30
    £1,174.00 £978.33
    £1,174.00 £978.33
  16. KW Variant 1 Coilovers For Audi S3 (8V) without electronic dampers for convertible - 10282016
    10282016
    • Model Year - 04/14-
    • Engine Power(KW) - 210-228
    • Lowering Front(mm) - 10-35
    • Lowering Rear(mm) - 0-25
    £1,174.00 £978.33
    £1,174.00 £978.33
  17. KW Variant 1 Coilovers For Audi S3 (8V) with electronic dampers incl. saloon + Sportback - 1021000T
    1021000T
    £1,371.00 £1,142.50
    £1,371.00 £1,142.50
  18. KW Variant 1 Coilovers For Audi S3 (8V) with electronic dampers for convertible - 102100AH
    102100AH
    £1,371.00 £1,142.50
    £1,371.00 £1,142.50
  19. KW Variant 1 Coilovers For Audi A3 (8YA/8YS) 2WD with 50mm susp strut without electronic dampers for Sportback with IRS - 102800CH
    102800CH
    • Model Year - 03/20-
    • Engine Power(KW) - 81-110
    • Max Weight - F: -1035 R: -975
    • Lowering Front(mm) - 35-60
    • Lowering Rear(mm) - 35-60
    £1,174.00 £978.33
    £1,174.00 £978.33
  20. KW Variant 1 Coilovers For Audi A3 (8YA/8YS) 2WD with 50mm susp strut without electronic dampers for Sportback with IRS - 102800CJ
    102800CJ
    • Max Weight - F: 1036-1090 R: -975
    £1,174.00 £978.33
    £1,174.00 £978.33
  21. KW Variant 1 Coilovers For Audi A3 (8YA/8YS) 2WD with 55mm susp strut without electronic dampers for Sportback with IRS - 102800CS
    102800CS
    £1,174.00 £978.33
    £1,174.00 £978.33
  22. KW Variant 1 Coilovers For Audi A3 (8YA/8YS) 2WD with 55mm susp strut without electronic dampers for Sportback with IRS - 102800CT
    102800CT
    £1,174.00 £978.33
    £1,174.00 £978.33
  23. KW Variant 1 Coilovers For Audi A3 (8YA/8YS) 2WD without electronic dampers for Sportback for 40 / 45 TFSIe Plug-in-Hybrid - 102100DL
    102100DL
    • Model Year - 10/20-
    • Max Weight - F: -1095 R: -1110
    £1,208.00 £1,006.67
    £1,208.00 £1,006.67
  24. KW Variant 1 Coilovers For Audi A4 (B5) 2WD for saloon, estate - 10210007
    10210007
    • Model Year - -01/99
    • Engine Power(KW) - 55-142
    • Max Weight - F: -1080 R: -1070
    • Lowering Front(mm) - 40-75
    • Lowering Rear(mm) - 40-75
    £936.00 £780.00
    £936.00 £780.00
