Tein Lowering Springs
136 Products
Set Descending Direction
  1. Tein S.TECH Lowering Springs for HONDA CIVIC EK3 - SKH26-S1B00
    SKH26-S1B00
    • Spring Rate - Front: 3.8kg / Rear: 2.5kg
    • Height Drop- Front: 27mm / Rear: 20mm
    • Compatible with OEM dampers
    • Green powder coat finish
    £168.00 £140.00
    £168.00 £140.00
  2. Tein S.TECH Lowering Springs for HONDA CIVIC EU1 - SKH86-S1B00
    SKH86-S1B00
    • Spring Rate - Front: 2.8kg / Rear: 5.2kg
    • Height Drop- Front: 40mm / Rear: 40mm
    £144.00 £120.00
    £144.00 £120.00
  3. Tein S.TECH Lowering Springs for HONDA CIVIC FK7 - SKHH6-AUB00
    SKHH6-AUB00
    • Spring Rate - Front: 2.6kg / Rear: 3.1kg
    • Height Drop- Front: 35mm / Rear: 35mm
    £168.00 £140.00
    £168.00 £140.00
  4. Tein S.TECH Lowering Springs for HONDA CIVIC FN2 - SKHA2-S1B00
    SKHA2-S1B00
    • Spring Rate - Front: 3.9kg / Rear: 3.3kg
    • Height Drop- Front: 15mm / Rear: 20mm
    £168.00 £140.00
    £168.00 £140.00
  5. Tein S.TECH Lowering Springs for HONDA CIVIC TYPE R EP3 - SKA12-AVB00
    SKA12-AVB00
    • Spring Rate - Front: 5.5kg / Rear: 9.2kg
    • Height Drop- Front: 25mm / Rear: 20mm
    £204.00 £170.00
    £204.00 £170.00
  6. Tein S.TECH Lowering Springs for HONDA CIVIC TYPE R FK8 - SKHK8-S1B00
    SKHK8-S1B00
    • Spring Rate - Front: 5.3kg / Rear: 4.8kg
    • Height Drop- Front: 25mm / Rear: 25mm
    £192.00 £160.00
    £192.00 £160.00
  7. Tein S.TECH Lowering Springs for HONDA CR-X ED9 - SKA36-AUB00
    SKA36-AUB00
    • Spring Rate - Front: 4.8kg / Rear: 2.2kg
    • Height Drop- Front: 40mm / Rear: 36mm
    £144.00 £120.00
    £144.00 £120.00
  8. Tein HIGH.TECH Lowering Springs for HONDA CR-Z ZF2 - SKHA6-G1B00
    SKHA6-G1B00
    • Spring Rate - Front: 2.2kg / Rear: 4kg
    • Gold powder coat finish
    £192.00 £160.00
    £192.00 £160.00
  9. Tein S.TECH Lowering Springs for HONDA FIT GE6 - SKB74-S1B00
    SKB74-S1B00
    • Spring Rate - Front: 2.3kg / Rear: 2.4kg
    • Height Drop- Front: 30mm / Rear: 45mm
    £168.00 £140.00
    £168.00 £140.00
  10. Tein S.TECH Lowering Springs for HONDA S2000 AP1 - SKA58-AVB00
    SKA58-AVB00
    • Spring Rate - Front: 5.3kg / Rear: 6.5kg
    • Height Drop- Front: 17mm / Rear: 16mm
    £156.00 £130.00
    £156.00 £130.00
  11. Tein S.TECH Lowering Springs for LEXUS GS300 GRS190L - SKL78-AUB00
    SKL78-AUB00
    • Spring Rate - Front: 4.1kg / Rear: 5kg
    • Height Drop- Front: 36mm / Rear: 29mm
    £180.00 £150.00
    £180.00 £150.00
  12. Tein S.TECH Lowering Springs for LEXUS GS300 JZS160L - SKY98-AUB00
    SKY98-AUB00
    • Spring Rate - Front: 6.8kg / Rear: 8.3kg
    • Height Drop- Front: 39mm / Rear: 27mm
    £204.00 £170.00
    £204.00 £170.00
  13. Tein S.TECH Lowering Springs for LEXUS GS430 UZS160L - SKY98-AUB00
    SKY98-AUB00
    • Height Drop- Front: 44mm / Rear: 44mm
    £204.00 £170.00
    £204.00 £170.00
  14. Tein S.TECH Lowering Springs for LEXUS GS430 UZS190L - SKL78-AUB00
    SKL78-AUB00
    • Height Drop- Front: 36mm / Rear: 21mm
    £180.00 £150.00
    £180.00 £150.00
  15. Tein HIGH.TECH Lowering Springs for LEXUS IS F USE20L - SKC72-BUB00
    SKC72-BUB00
    • Spring Rate - Front: 8.1kg / Rear: 6.8kg
    • Height Drop- Front: 25mm / Rear: 15mm
    £192.00 £160.00
    £192.00 £160.00
  16. Tein S.TECH Lowering Springs for LEXUS IS200T ASE30L - SKQ74-AUB00
    SKQ74-AUB00
    • Spring Rate - Front: 6kg / Rear: 8.5kg
    • Height Drop- Front: 35mm / Rear: 45mm
    £192.00 £160.00
    £192.00 £160.00
  17. Tein S.TECH Lowering Springs for LEXUS IS250 GSE20L - SKL90-AUB00
    SKL90-AUB00
    • Spring Rate - Front: 6.5kg / Rear: 6.8kg
    • Height Drop- Front: 44mm / Rear: 25mm
    £204.00 £170.00
    £204.00 £170.00
  18. Tein S.TECH Lowering Springs for LEXUS IS250 GSE30L - SKQ74-AUB00
    SKQ74-AUB00
    • Height Drop- Front: 30mm / Rear: 25mm
    £192.00 £160.00
    £192.00 £160.00
  19. Tein S.TECH Lowering Springs for LEXUS IS300 JCE10L - SKY94-AUB00
    SKY94-AUB00
    • Spring Rate - Front: 4.9kg / Rear: 3.8kg
    • Height Drop- Front: 32mm / Rear: 39mm
    £180.00 £150.00
    £180.00 £150.00
  20. Tein S.TECH Lowering Springs for LEXUS IS350 GSE31L - SKQ74-AUB00
    SKQ74-AUB00
    • Height Drop- Front: 35mm / Rear: 25mm
    £192.00 £160.00
    £192.00 £160.00
  21. Tein HIGH.TECH Lowering Springs for MAZDA AXELA SPORT BLEFW - SKM98-G1B00
    SKM98-G1B00
    • Spring Rate - Front: 2.8kg / Rear: 2.4kg
    • Height Drop- Front: 30mm / Rear: 30mm
    £180.00 £150.00
    £180.00 £150.00
  22. Tein S.TECH Lowering Springs for MAZDA DEMIO DEJFS - SKM90-S1B00
    SKM90-S1B00
    • Spring Rate - Front: 2.4kg / Rear: 2kg
    • Height Drop- Front: 45mm / Rear: 35mm
    £0.00 £0.00
    Out of stock
    £0.00 £0.00
  23. Tein HIGH.TECH Lowering Springs for MAZDA DEMIO DJ5FS - SKMC2-G1B00
    SKMC2-G1B00
    • Spring Rate - Front: 2.4kg / Rear: 2.7kg
    £180.00 £150.00
    £180.00 £150.00
  24. Tein S.TECH Lowering Springs for MAZDA MAZDA2 DE# - SKM90-S1B00
    SKM90-S1B00
    • Height Drop- Front: 40mm / Rear: 45mm
    £0.00 £0.00
    Out of stock
    £0.00 £0.00
