Coilovers and Dampers
Suspension
Filter
Filter
Car Make | Model
Brand
Filter
Set Ascending Direction
145-168 of 1648
Loading Products
Coilover Suspension
Coilovers are usually one of the most important and noticeable modifications to carry out on your car. Their is no doubt a slammed car looks awesome but the benefits of lowering your car don't just stop with how it looks, the handling and braking performance is also dramatically improved too. Because coilover suspension is designed to reduce ride height at a physical point without reducing suspension travel, the stress exerted on suspension components and sensitive car electronics is also lessened too. By upgrading your OEM suspension with coilovers you can dial in the perfect ride height and damping adjustment to create the perfect setup for you and your driving style, meaning faster lap times or a firmer ride around town.
We stock coilover suspension kits for a wide range of cars from leading manufacturers including HSD Coilovers, KW Suspension, Tein Coilovers, Dampers and Lowering Springs, and BC Racing Coilovers, each catering for a different budget no matter how big or small. However, if you're just looking to replace your existing coilover setup with firmer or softer springs then choose from our selection of Coilover Springs from HSD and Swift Springs to help fine tune and compliment your ride even further.
We pride ourselves on delivering the best customer service and advice when it comes to setting up your coilovers straight out of the box. Call or email the Driftworks technical sales team and they can help guide you through the best setup for your car whether you intend to use it for track only or as a daily driver.
Get the latest product releases & offers...
Top
