big
small
Alloy Wheels
Wheels & Accessories
Alloy Wheels
Filter
Filter
Wheel PCD / Stud Pattern
Wheel Size
Brand
Colour
Wheel Width
Wheel Model
Wheel Structure
Filter
Set Ascending Direction
97-120 of 8657
Loading Products
Alloy Wheels
Alloy wheels can make or break the look of your car. Choosing an incorrect wheel design, getting the wheel fitment wrong or even making a bad colour choice can make your car look far from desirable. Here at Driftworks, thanks to our years of wheel fitment knowledge, experience and buying power, we can offer you a huge range of aftermarket alloy wheels along with the very best technical support. Whether you're after custom 2 or 3-piece Work Wheels from Japan or just want to inject some life into your car without breaking the bank, we have something for everyone from the biggest brands Work Wheels, Japan Racing, Rota, BBS, Rotiform plus loads more. To make installation easier we also provide a wide range of wheel bolts, tuner wheel nuts and tyres to help put together a killer combo that not only looks awesome but performs too.
So you know what wheels you want but have no idea what wheel diameter, width or PCD fits your car. Don't worry, our technical wheel experts are on hand to give you all the info you'll ever need to help you reach the holy grail of wheel fitment. Alternatively, check out willtheyfit.com. and fine tune the wheel fitment to make sure your new alloy wheels work with any modifications such as Big Brake Kits, Coilovers or Tyres you may already have or are thinking of installing.
However, when choosing alloy wheels you still have a number of options available to you depending on how far you want to go with your build. A bolt-on fitment means exactly that, you can grab a set of wheels and simply fit them straight to your car without any issues. But if you're after something a little more special then go for a modified or extreme fitment. These types of fitment require some work either rolling or cutting the arches but by doing so you can fit much bigger, wider wheels that not only look better but also give you improved grip.
Check out our range of wheel and tyre brands:
Work Wheels | Japan Racing (JR) Alloy Wheels | Rota Alloy Wheels | BBS Alloy Wheels | Concaver Alloy Wheels | Bola Alloy Wheels | 3SDM Alloy Wheels | Rotiform Alloy Wheels | 1Form Alloy Wheels | Fifteen52 Alloy Wheels | 7Twenty Alloy Wheels | Linea Corse Alloy Wheels | Nankang Tyres | Westlake Tyres
Get the latest product releases & offers...
Top
