Need help identifying calipers
Thread in 'Technical Questions' started by bigdave z20, Sep 19, 2014.
  1. bigdave z20
    bigdave z20 Member
    Imported my gz20 soarer (based on the mk3 supra) and it came with a set of 4 pot front calipers off another car. However the pads are close to their limit so need to find out what they are so I can get the appropriate pads.
    They are Sumitomo 4 pots and have '8Y8' stamped on them.
    Has anyone seen them before?
  2. bigdave z20
    bigdave z20 Member
    Is it possible to be nissan s14/15 4 pots but with the nissan removed?
    They have adapter brackets on them so they aren't an OEM fit to my car
  3. Boxertricks
    Boxertricks Member
    Are they ally LS400 4 pots?
  4. r3k1355
    r3k1355 Well-Known Member
    S14 calipers are steel, so see if a magnet will stick.
  5. el_bandido
    el_bandido Member
    No, looks completely wrong.
  6. Martin P
    Martin P Member
    300zx z32?
  7. bigdave z20
    bigdave z20 Member
    Mate called round in his s15 today and they look identical. Will borrow one of his pads to see if it fits. Spent days looking at calipers online, hope they fit or il be back to OEM brakes
  8. MaxS15
    MaxS15 New Member
    Yeh, they look just like cast s14/15 ones, which would make the discs 280mm
    Most skyline ones are aluminium and have slightly softer, more curved edges. I have had both types on my s15 and these are the standard sbody ones
  9. bigdave z20
    bigdave z20 Member
    Awesome max, cheers
    Would be great if they were s15 brakes. Easy to get pads for
  10. gaz_moose
    gaz_moose .MTM.
    s14 s15 300zx r32 Subaru all use the same pads mate. 280mmx30mm discs. they look like steel s14/Subaru ones.
    when you order pads tell them they are for a 200sx 1995-2001.
  11. bigdave z20
    bigdave z20 Member
    Cheers gaz, getting the lend of an old s15 pad this week to see if it fits. Will be a big relief if they do!
  12. bigdave z20
    bigdave z20 Member
    Got sorted, they're the nissan calipers. Thanks for your help guys :)
    What are these calipers like, are they often upgraded to anything else?
  13. r3k1355
    You can fit some Alloy ones, 300ZX or Skyline GTS-T.
    IIRC the Skyline ones use a larger disc as well.
  14. bigdave z20
    bigdave z20 Member
    Cool, will keep an eye out for some
  15. gaz_moose
    gaz_moose .MTM.
    the 300zx/r32 gtst alloy calipers are a bit physically bigger. r33gtst/r32 gtr use bigger discs/calipers from memory they are 296mm
    all vented discs.
    the calipers are ok they stand upto a bit of track work with decent pads discs fitted.
