For Sale Breaking R32 Skyline drift/track/race car
Thread in 'Parts for sale' started by chodjinn, Mar 7, 2022.
  1. chodjinn
    chodjinn Active Member
    Breaking my 1990 R32 Skyline GTS-T drift/track car. I have a build thread on here somewhere but it's pretty out of date. I need to sell the shell first ideally but listing the main parts here.
    If you wanna contact me for pics, Whatapp usually best 07790 77 _FIVE 39 _ONE, or message me on here or facebook (olly hayter)
    R32 Skyline shell, complete with all panels and windows, brackets and bits etc. Every single bit of metal that could be removed was to make it mega light.
    Macpherson strut front conversion, massive tubs, rebuilt/reinforced strut tops, massive cage by owen motorsports, rear firewall, boot floor removed, fuel cell and rear rad mounts, tubbed and raised rear arches, big intercooler spaceframe mount
    Bare metal restoration, resealed, primed & painted. Mercedes Arctic White on the outside, gloss black boot & engine bay, neon yellow interior, has not been outside since paint.. Shell comes with full door/boot seals, scuttle panel
    Plastic4performace 4mm lexan window kit (rear, side, doors).
    Genuine windscreen and new rubber
    Gutted superlight doors with 4mm foamlux cards
    GKTech Ganador replica mirrors
    Gutted boot lid with rear rad intake & PS13 Rocket Bunny spoiler blended in
    GTR +50mm replica fibreglass overfenders
    TBO sideskirts (genuine)
    Bee-R R324 front end conversion - wings, bonnet, bumper (cut for side exit exhaust). Bonnet cut for V8 clearance
    Custom R34 headlight blanks (+moulds)
    Comes with WRC sill stand kit (new, unfitted)
    RK Tuning replica superlight R32 dashboard and carbon insert
    3mm alloy Chequer floor plates
    S13 Steering column and NASCAR mounts to dash bar
    Wiper motor/linkage and spare
    £8.5k rolling shell with all chassis parts and rota journey rims
    £6k shell only
    Chassis
    Tein Flex coilovers, S13 fitment F&R, one rear adjuster is stiff £395
    Random NEW rear coilovers, might be maxpeedingrods £50
    Rear Mk1 Geomasters with v.good 5 stud hubs £300
    Almost new 5 stud hubs rear £95
    Front Mk1 Geomasters, modified with extra lock mod and reinforcement. Comes with extra long high tensile bolts £200
    Rear S14 subframe with Driftworks risers for R32/S13 £100
    S13 rear diff 3.9 and 3x2 shafts £200
    Rear S14 subframe standard £50
    Front S14 subframe standard x2 £50 each
    S14 steering rack, Superpro blue bushes, depowered to manual correctly £100
    NEW Japspeed Heavy Duty steering arms & rose-jointed steering rod ends & spare set of another set of steering arms a slightly different length £75
    NEW Japspeed adjustable lower front control arms with Driftworks bushes and rose joints £125
    Aluminium lightweight front tension rods w/rose joints £50
    DRIFTWORKS Rear Traction Rods & Toe Rods £125
    CUSCO Rear ARB & mounts/bolts with poly bushes powdercoated white £120
    Whiteline adjustable front anti roll bar & mounts £120
    Brakes
    Front K-sport 8 pots and 356mm 2-piece rotors £750
    Rear R33 Skyline Brembos (in pink!) and Z32 vented discs £300
    Bias pedal box with 3 master cylinders, 3 remote resevoirs and hoses £300
    Driftworks handbrake £35
    AP Racing rear brake bias £50
    Fuel System
    30l ATL fuel tank with AN fittings, AN10 feed on bottom
    3 litre custom tall-tower fuel swirl pot, double internal baffles, all welded AN fittings
    Bosch 413 main pump (the big daddy of the 044), Bosch 044 lift pump
    2x new disposable Sytec motorsport 6 micron filters with AN6 fittings
    Aeromotive FPR with twin returns from rail and AN10 return to tank
    Fully braided hoses including AN10 feed to engine bay, all pump fittings brand new
    Custom boot mounted fuel filler with hose to tank
    £750
    Rear Radiator & Oil Cooler
    Touring car ultra lightweight race radiator, modified with AN20 fittings
    Laminoca/Mocal oil/water heat exchanger (the big one) with AN20 water / AN10 oil fittings
    Custom rear micro bleed pot AN6
    AN20 radiator lines front to back (£££)
    AN10 oil lines
    Torques remote 4-port oil filter head, new filter, AN10
    NASCAR header tank with pressure cap
    This cost me aboou £1350 to have made/built.
    £1k ono
    Wheels/tyres
    Rota GTR-D Black, v.good condition18" x 10" ET12 all round x4 with Conti Sport 3 235/35/18 front, Pirelli 255/35/18 rear £595
    Rota Journey White 18" x 10" ET15 all round x4 with 225/35/18 front, 245/35/18 rear £350
    NEW 18" Dunlop slicks £250
    NEW 18" Pirelli Wets £300
    Driftworks internal drive wheel nuts and adapter £25
    Other bits
    MOMO steering wheel £60
    Mountney Steering wheel boss £35
    Sparco Quick release steering fitting £20
    Boat big Electric interior fan £20
    Mocal Oil pressure & temp gauge, mechanical, with capillary kit & Mocal water temp gauge, mechanical £95
    Plumbed in fire extinguisher, mount & pull cords (out of date) £65
    FIA batter isolation switch, kill switch & pull cords £15
    RED motorsport Plastic battery box £20
    Folia-Tec tow hook £10
    MSA LED Rain Light 52mm and mount £15
    Big 5" tachometer/shift light £30
    25mm front wheel spacers £10
    Random red suede Dished steering wheel £25
    NEW Massive Porsche 911 RSR BMC Carbon Air Filter £65
    R32 GTR Carbon canards £35
    R32 Skyline Rear tailgate with Nismo lip, carbon wrap £195
    Racing wing mirrors, single seater style with carbon mounts for R32 doors £20
    Engine
    1UZFE V8 LS400 early thick rod standard with brand new sump, turbo oil return, AN10 rocker fittings, polished inlet manifold, several throttle bodies (including 1 with uber rare traction control) £1,000
    DriftMoto BMW manual conversion 1UZFE twin plate 800bhp rated kit with new slave cylinder, AN fittings, braided hose, 2x BMW ZF gearboxes £1750 (cost almost £3k)
    New NP Parts BMW short shifter and custom gearbox tunnel mount, includes hydro mount £200
    MS3 Pro ECU with COP kit, DENSO coils, carbo coil covers, 3x bosch pressure sensors (oil/water/fuel) plus brand new loom to full 1UZFE engine, IAT, TPS and 3 bar sensors, dual knock sensor kit, all brand new with 400bhp base map £1300ono
    1UZ Milner Carbon Fibre engine cover £150
    Zurawskit Motorsport turbo manifolds, twin scroll with twin 38mm wastegate fittings £1,150ono
    Turbonetics T4 Hurricane Vanessa turbo, bought new and only had running for engine startup £650ono
    NEW Titanium T4 turbo blanket £25
    Trubonetics Godzilla BOV and pipework £125
    Turbonetics RG45 Racegate external wastegate and screamer pipe £125
    Massive 600x300mm x 100mm thick 800bhp rated equal flow intercooler with carbon fibre ducting (front & rear) and vbands, plus loads of pipework £350
    MAC boost solenoid, AN6 fittings and hoses £50
    Innovate LC-1 Wideband full kit with gauge £120
    Titanium silencer with 4" inlet and 5" tip, mega light £250
    Custom Group A spec oil separator/breather system including 5-pot Graham Goode separator and custom 2.5 litre catch tank, all AN10 with lines £350
    #1 chodjinn, Mar 7, 2022
  2. Chazza_13
    Chazza_13 Member
    Lincoln
    Hi mate do you have the front indicator looms?
  3. chodjinn
    It doesn't even have front indicators dude, it's a f--king race car.
    • Funny Funny x 1
  4. Jfedz
    Jfedz New Member
    UK
    Hi,
    What's the centre bore of your spacers and what brand are they?
    Thanks
  5. chodjinn
    H&R 25mm
    #5 chodjinn, Mar 11, 2022
  6. chodjinn
    Ideally need to sell as a rolling shell and it needs to go asap due to needing the space so open to reasonable offers!
  7. Jfedz
    Jfedz New Member
    UK
    Would it be possible to post a photo of them on here or would Facebook messenger be easier?
  8. chodjinn
    messenger or whatsapp. I'm removing the brakes tonight so the spacers will also come off
  9. chodjinn
    open to offers on shell / rolling shell needs to go in the next fortnight
  10. Chunky Nugget
    Chunky Nugget honkeytits!!
    Aldershot
    hello mate, have you got the heater controls?
  11. chodjinn
    hahahahahaha. No.
  12. NismoTNR
    NismoTNR New Member
    Stockholm
    Hey, can you send some pics on whatsapp on the steering wheel?
    Whatsapp: +46702628783
    Cheers
  13. jamesd
    jamesd Member
    Cork,Ireland
    Which driftwirks hydro is it? Braided lines there too?
  14. chodjinn
    It's actually an OBP hydro i checked this wkend, I have some braided lines
  15. Walkies
    Walkies New Member
    Aberdeen
    Have you got the complete interior harness with fuse box etc?
  16. smurf
    smurf Member
    Northern ireland
    Any pics of steering boss?
  17. jamesd
    jamesd Member
    Cork,Ireland
    Any pics? What cylinder has it
  18. klim
    klim New Member
    Estonia
    Hello! Rear diff converted to fit s14 subframe?
  19. chodjinn
    Yes, I had an S14 subframe fitted to the Skyline
  20. chodjinn
    Can't edit priginal post so here is the updated list/prices
